 Post subject: Small..feature request :add tray icons'size config for DOCK
PostPosted: Sat Dec 23, 2017 10:04 pm
Well, the title sais it all:
add size configuration
for DOCKS' TRAY ICONS.
This already exists for the NextSTART
but not for the docks in workshelf.
This would make Docks a very good taskbar
replacement method
(not that they re not good but
with this they would be better)
 Post subject: Re: Small..feature request :add tray icons'size config for D
PostPosted: Sat Dec 23, 2017 11:20 pm
I'm sorry, but I'm not sure I understand your suggestion. Tray icons in the dock must obviously be the same size as all other icons, that's just how docks work. You cannot pick and choose the size of *each* icon in the dock, you can define an icon size, but it applies to all icons in the dock.
This said, you already have a pretty good alternative, which is grouping tray icons into a 16x16 grid.
PostPosted: Sun Dec 24, 2017 12:09 pm
I noticed in that 16x16 grid the tray icons take
some different forms depending on the dock's icons'size:
1 group, 4x4 icons many groups, etc
Is it possible to have this as an option
indipendent from dock's icons size?????
PostPosted: Sun Dec 24, 2017 1:02 pm
No, sorry.
PostPosted: Sun Dec 24, 2017 3:17 pm
Oh, well, I STILL LOVE YOU!!!!!
PostPosted: Sun Dec 24, 2017 3:22 pm
Thank you! Love you too, Merry Xmas! :D
Users browsing this forum: Majestic-12 [Bot] and 170 guests
