 Post subject: List of all bitmaps referenced by startbar, workshelf etc.
PostPosted: Sun Feb 25, 2007 2:31 pm
Hi,
I'm trying to find a complete list of all bitmaps that can be used/referenced in winstep. The bundled themes and tutorials give some hints, but I think there must be more - and more to be explained. For example, I quickly found out the function of task.bmp, start.bmp and so on. But I still don't know if there is a special bitmap defining a background (tile) for the systray - is there any?
A complete list of these bitmap files and their function would be very helpful.
best regards,
maddi
PostPosted: Sun Feb 25, 2007 4:42 pm
In the Help files of NextSTART and WorkShelf there is a complete list of all the bitmaps used: just open the Preferences screen of each application and click on the Help button. You can find the bitmap names list in the 'Theme Bitmaps' sub-section of 'Working with Themes' of both Help files.
Note that the Help file for WorkShelf has the list of bitmaps used for WorkShelf and NeXuS, and that the NextSTART help file has the list of bitmaps used to skin NextSTART (the menus, startbar, systray, etc...).
Users browsing this forum: Amazon [Bot], Google [Bot] and 156 guests
