 Post subject: Automatic Upgrade - Lost License
PostPosted: Sat Jan 06, 2018 6:55 am
Jorge,
Winstep upgraded automatically to 17.1. Wasn't expecting that and not prepared to renew subscription at this time. Is it possible to get previous build I was licensed for?
EDIT: Nevermind; problem solved. Subscription still good.
Cheers!
Chuck
 Post subject: Re: Automatic Upgrade - Lost License
PostPosted: Sat Jan 06, 2018 9:18 am
Glad you sorted it out, but what do you mean by 'upgraded automatically' ?
The Winstep Update Manager won't install anything without your permission first, and it will also warn you if it detects your license key is no longer valid for the new version.
PostPosted: Sat Jan 06, 2018 10:38 am
While I recall seeing Winstep update popup, I do not recall telling Winstep to actually make the update. I would not even have noticed except for trying to make a change to Winstep and getting the "this is a trial version" popup.
Cheers!
Chuck
Users browsing this forum: Amazon [Bot], Google [Bot] and 193 guests
