 Post subject: SubDock Icon Size
PostPosted: Mon Apr 09, 2018 9:30 pm
After the recent update, all of the icons on my subdocks are magnified to huge sizes unless they'd go off the screen, in which case they are all a bit smaller. I can't seem to find any way to control their size, only the size of icons on the main dock. It's mostly just an annoyance, but it's absolutely hideous. :/
 Post subject: Re: SubDock Icon Size
PostPosted: Mon Apr 09, 2018 10:32 pm
1. What is your screen DPI?
2. in Preferences -> General tab -> More Options -> Is the 'Disable dock scaling on high DPI settings' checked or unchecked?
3. Right click on the sub-dock's parent icon, select Sub-dock Properties, what's the icon size set to in the Appearance tab?
PostPosted: Mon Apr 09, 2018 11:19 pm
Found it after trying to figure out your number 3 question, as that option was missing for me. I had to go to:
Preferences -> Docks and Shelves tab -> Properties -> Behavior tab -> Sub-Docks
Some things in there were checked that must have been changed during the update. I've unchecked them and now I have control proper control over sub-docks again.
PostPosted: Mon Apr 09, 2018 11:51 pm
What version were you running before?
I take care not to let updates change user settings (backwards compatibility has always been very important to me), so something like that should not have happened.
Anyone else experiencing this?
Also, what settings were checked that shouldn't have been? Just the 'sub-docks inherit...' ?
Users browsing this forum: Amazon [Bot] and 210 guests
