 Post subject: More than One Weather Module??
PostPosted: Fri May 11, 2018 4:15 am
I am a new user. I am wondering if it is possible to have multiple desktop Weather modules? I would also like Multiple Clocks as well (not as important).
I have a desire to know the weather in a number of different cities that I do business in...
But it appears I can only have one weather Module?
Am I missing something - or is this a limitation of the program?
Thank you
Bradley
 Post subject: Re: More than One Weather Module??
PostPosted: Fri May 11, 2018 12:17 pm
For now it is indeed a limitation.
This said, multiple module instances are already in the to-do list.
PostPosted: Fri May 11, 2018 3:45 pm
As and when you're at that, why not the same for everything? ;)
Granted, Nextstart already has the possibility in that we can configure different menus and hotspots and use these with different VDs. A differently configured Nexus and Workshelf might actually be quite useful too in that context.
PostPosted: Fri May 11, 2018 10:43 pm
Hello Jorge,
Ok - thank you for confirming the limitation. The next question is can you provide a rough guess as to when you might be able to add this feature? I am not looking for exact date - just a rough guess... Something like 3 months, or 6 months, or 2 years... :)
Bradley
PostPosted: Fri May 11, 2018 11:41 pm
You should know better than to ask that question to a developer. :)
The only honest answer is: it will be ready when it's ready. :wink:
Users browsing this forum: Majestic-12 [Bot] and 179 guests
