 Post subject: Mysterious icon on desktop
PostPosted: Sun May 20, 2018 9:26 pm
I have most recent version of Nexus Dock installed in default configuration. When Nexus dock starts, an unclickable icon with letters Wo appears on desktop. If I exit the dock, it disappears. I've reinstalled and reset everything to defaults. Suggestions? I do notice if I restart Explorer from the task manager, it does go away.
Suggestions? Drives me crazy as it's in the middle of the desktop.
File comment: Mysterious icon
 Post subject: Re: Mysterious icon on desktop
PostPosted: Mon May 21, 2018 8:41 am
Well, that's not an icon - it's the application's control window.
That window is not supposed to be visible, i.e.; it is deliberately hidden, so something else in your system is making it visible. Any idea what that might be?
Anyway, in the next beta I'll try to position the window off-screen as well. It was supposed to be off-screen already, but the coordinates used were valid only when we all run screen resolutions of 1024x768, tops ehehe. With current screen resolutions if something makes it visible, as it happens in your case, it will appear smack in the middle of the screen. :)
Also, what version of Nexus are you running?
PostPosted: Tue May 22, 2018 6:46 am
How do you stop it from showing up on the screen, I have one as well? I wonder why it remains to be visible in such a long run.
PostPosted: Mon Jun 04, 2018 6:24 am
So, did v18.5 fix this issue?
Users browsing this forum: Amazon [Bot], Google [Bot], Majestic-12 [Bot] and 153 guests
