 Post subject: File VBS ...not found on the dock
PostPosted: Sun Sep 02, 2018 9:24 am
I use a file Power-off.vbs to power-off my nas and i i put this shurtcut on dock every time a message appear:
Windows Script Host:
Error: impossible find file
Code: 80070002
but the file is present in the folder. In which way a can solve ?
With same configuration run without problem on my objectdock
Thank
Hispa
 Post subject: Re: File VBS ...not found on the dock
PostPosted: Sun Sep 02, 2018 9:27 am
Probably a 32 bit vs. 64 bit file re-direction issue.
Where is the .vbs file located? Have you tried already setting the shortcut in the dock to point directly to the script engine executable, using the .vbs file as an argument?
PostPosted: Sun Sep 02, 2018 10:46 am
It is in
C:\Program Files (x86)\Wol\Power-off halt5.vbs
I have windows 10 64bit
Thank
Hispa
PostPosted: Sun Sep 02, 2018 10:51 am
Move the vbs file to some location other than C:\Program Files\ or C:\Program Files (x86)\
That is what is causing the problems.
PostPosted: Sun Sep 02, 2018 11:04 am
THANKKKKKKKKKKKK !
Good day bro
Hispa
Users browsing this forum: ppetroff60 and 297 guests
