Board index : Winstep Forums : General Discussion  [ 21 posts ] Go to page Previous  1, 2
 Post subject: Re: Pin UWP apps to Nexus?
PostPosted: Wed Sep 19, 2018 4:32 am
...AND fixed for next release! :)
Not even using the pathname but the actual window classname to identify these UWP/Win32 hybrid applications.
If you pin them to the dock they now get properly pinned as a UWP app (instead of a Win32 executable) and the running indicator properly displays under the icon if the app is currently running.
PostPosted: Wed Sep 19, 2018 6:17 am
Wow, that was impressively fast! Thanks for fixing that so quickly :) .
PostPosted: Wed Sep 19, 2018 6:35 am
Thanks for reporting it. Can't fix what I don't know about. :)
PostPosted: Wed Sep 19, 2018 7:24 am
You're welcome. It's not close to a big deal for me, though I like knowing I could help making Nexus a little better :).
By the way, what I just realised: I have a two-screen setup, and decided to have my main screen (you can assign it in Windows) on the left (1) and Nexus on the right (2) screen. Even though I ticked 'hide task bar', the task bar still appears on the right screen (2, where Nexus is located), and is only hidden on the other screen (1). I just switched back to have Nexus and the main screen on 2, but would think that someone might just stumble upon it :) .
PostPosted: Thu Sep 20, 2018 8:27 pm
Certain things (like that one) will have to wait for me to switch my main development environment from Windows 7 to Windows 10 (although I will do that kicking and screaming). Windows 7, as you know, does not support individual taskbars per monitor.
PostPosted: Tue Oct 09, 2018 5:19 pm
Should have used the pathname instead... looks like my fix is incomplete and will not work with all Win32/UWP hybrids. :(
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 21 posts ] Go to page Previous  1, 2
Users browsing this forum: Google [Bot] and 237 guests
