Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 45  Next
PostPosted: Sun Oct 28, 2018 7:34 pm
Err, there is only a majority now that you stated your opinion - and even then it's a majority of two lol.
.... If you think about it, makes all the sense in the word: GStacks are no different than tabs in Shelves. The icons in a Shelf tab do not get cached until you actually open the tab. So, if this is the way it works with the tabs in your Shelf, there is no reason in the world why it shouldn't also work that way with GStacks.
Plus, there actually is a huge difference in performance between opening a cached GStack and a non cached GStack (and image thumbnails already appear rendered the second time around)....
LOL! OK, all long understood Jorge, and now conceded. :)
1) WRT GridStacks, it should be possible - at least in theory - to have a GS icon in a shelf say and then have a QL Hotspot pointing to this? But would the GS then open relative to the original icon, or to the hotspot?
I don't know yet if that is a good idea, still have to think about it. Anyway, in either case it would open relative to the hotspot.
If that was to work fine, then great, that would do very nicely IMO. No need for a direct, independent hotspot then really, so less work. :)
2) What lines do I have to use in the config file to save the in-shelf/-dock etc. histo colour to the theme?
Sigh. Those are defined in the configuration files of the modules themselves:
GraphColor
Sigh. Bugger! And I blindly thought that only referred to the colour with non-advs skinning. :)
3) What lines do I have to use in the config file to save the icon frames/grid colours to the theme?
ActiveFrameColor1
ActiveFrameColor2
Wasn't quite sure what those lines referred to actually. Bummer.
Anyway, thank you so much for taking time out and helping solve these little puzzles for me Jorge, appreciate it.
PostPosted: Sun Oct 28, 2018 8:00 pm
Vlad wrote:
When I was changing it from the default C:/ to the Music folder I got some crashes. Now is working well.
How did you change the folder?
Can you reproduce this consistently?
Vlad wrote:
They are coded the same way, work in other players, the playlist is generated correctly, but the same files gets skipped on playing. Guess is something codec related... Don`t know how the Winstep MPlayer uses the system codecs.
Could be a 64 bit vs. 32 bit issue:
Codecs come in separate 64 bit and 32 bit packages. A 64 bit codec cannot be used by a 32 bit media player and vice-versa.
Normally you have to install two versions of the same codec pack: one the 32 bit version, the other the 64 bit version.
If you only have the 64 bit codecs installed, 64 bit media players will be fine, but not the 32 bit media players such as the Winstep Media Player.
Also, can you please double check that WsMMPlay.exe is running when you are listening to MP3 files using the Winstep Media Player?
Vlad wrote:
Question: Does it makes sense to you to have the icon that opens the grid also be usable as a shortcut? (in the way a shortcut icon can have a nested subdock).
No. For starters, Grid Stacks do not have sub-dock indicators. And even if they did, there would be a conflict between showing the Grid Stack or the sub-dock when clicking on the indicator.
PostPosted: Sun Oct 28, 2018 8:24 pm
Right click/change folder. It did not work the first 2-3 times. Then I used the Grid Proprieties and tried to browse the path, same problem, then I pasted the path and it worked. Now it is working either way.
I am listening right now via Winstep Media Player and WsMMPlay.exe is not running.
I was in doubt about that, did not know how could that be translated to grids. I liked the fact that I could have a program launch (like my main web browser) via an icon and also have a subdock attached to that icon with the other browsers. I have a few icons configured like that. Well, I guess I will keep some with the subdock attached and others are already turned into grids for good.
PostPosted: Sun Oct 28, 2018 8:51 pm
Well, that all seems to have worked out just dandy, thanks again Jorge. So now you have a theme that actually uses the digital clock, both in-shelf/-dock etc., *and* that uses colour-coordinated frames in the shelf! :) (And even properly matched up in-shelf/-dock histo colours! LOL!
See the (prior to changes) screen grab and my idea for the startmenu here : https://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=10870
PostPosted: Sun Oct 28, 2018 9:11 pm
Also I noticed that the inverted vertical drawers are still having issues regarding positioning. Although those do not jump around on drag and drop anymore, they still change position after a restart of the workshelf.
PostPosted: Sun Oct 28, 2018 9:32 pm
how about gstack being a standalone feature like a dock or drawer, not just sub-stack from shelf/dock/drawer?
Wouldn't that be exactly the same as a single tabbed Shelf set to show a fixed number of icon rows?
now that you mention it i guess it would
edit: my thinking was more that once you have a grid you might want to 'pull it' away from his parent dock/shelf and have it standalone
PostPosted: Sun Oct 28, 2018 9:46 pm
Ah, like the detachable menus in NextSTART. :)
Problem is, you can already drag GStacks around (and even resize, although the new size will not be remembered once you close them) which is kind of incompatible with the idea of detachable GStacks.
PostPosted: Sun Oct 28, 2018 10:09 pm
more like subdocks but yeah
shame
PostPosted: Sun Oct 28, 2018 10:23 pm
NOT running? Why the hell not? Did you delete it from C:\Program Files (x86)\Winstep\ ?
That could be the cause of all your errors right there. There's a reason the Winstep application uses an external applet to play MP3 files, and Seeker has first hand experience on why, with weird random crashes happening to him too: just read this mammoth thread here to understand how difficult it was to diagnose this problem (things escalate quickly to a solution from page 5 onward lol).
Basically bad MP3 codecs can corrupt the main memory space of the Winstep application if it plays them directly (and that is exactly what it does if it cannot launch WsMMPlay.exe for some reason).
PostPosted: Sun Oct 28, 2018 10:39 pm
PH3WWW!!! fin@11y!! :cry:
1 f0und a w@& t0 t@lk t0 &ou thr0ugh @n int3rdiment1on@l v0rt3x, I h@ß3 sp3nt th3 l@st 50 y3@rs try1ng t0 r3@ch y0u.
I haß3 v3ry li11l3 t1m3 s0 r3@d c@r3fu11y!!!
D0 N0T try t0 m0v3 0r c0py v1@ dr@g $ dr0p @n 3x1st1ng Gr1d St@ck t0 @ Sh3lf, @n0th3r Grid St@ck 0r @ Dr@w3r. 1 r3p3@t!! D0 N0T try m0v3 @ Grid St@ck in @ Sh3lf, @noth3r Grid St@ck 0r @ Dr@w3r int0 @n0th3r p0siti0n 0r t@b.
1f y0u d0 s0 y0u11 r3gr3t it lik3 m3. :(
0h n0!! th3re th3y c0m3!!! :shock: I g0tt@ g0! :o
PostPosted: Sun Oct 28, 2018 10:48 pm
LOL! Ooops... sorry about that...
When you are running a beta, especially one that messes with internal structures, there is always a possibility of something going terribly wrong, which is why I recommended making a backup before installing the beta.
In this case the issue was not even a bug in the code, it was something really, really, really stupid: I forgot to declare a variable inside the OLE drop routine, and because a function with the same name existed elsewhere, instead of throwing a 'variable not found' error (which would have immediately alerted me to the error) it run the function instead - which in turn corrupted the internal pointer that lets the Shelf know which Shelf it is.
Basically gave it an identity crisis. :)
PostPosted: Sun Oct 28, 2018 11:40 pm
1t's c0ld h3r3.
C@n 1 just dr0p th3 OL3 r0utin3?
1'm sc@r3d. I just w@nn@ g0 h0m3 und3r @ bl@nk3t. :(
...just joking, I didn't dare to put a grid inside a grid. :mrgreen:
PostPosted: Sun Oct 28, 2018 11:59 pm
LOL. That would have indeed created an inter-dimensional wormhole right under your feet and suck you into an alternate universe. :wink:
PostPosted: Mon Oct 29, 2018 6:22 am
You want to control what users can and cannot do, and I want users to be free! I'm fighting for freedom, you are fighting for oppression LOL LOL :P :wink:
LOLOL! Ballcocks, Jorge! ;) Freedom is a much abused word. It's one of the things that's f***ed up this society in the first place - the 'freedom' of the individual placed above the well-being of the community and the society as a whole.
Users need constraints to some extent in the context of any programme. I'm just advocating sensible, simple common-sense constraints (and that includes, btw., the constraint not to infringe the skinner's copyright!) on how themes are presented to and used by the user. Users still have the choice not to use a given theme if they don't like the constraints it presents, and to choose another theme instead. Simple. :P
Jorge, in Soviet RiKistan (changed from C because Soviet/Cyrillic C means something else) the theme controls the user. ;-)
PostPosted: Mon Oct 29, 2018 8:30 am
Ehehehe. :lol: See, Ric?! :wink:
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 675 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 45  Next
Users browsing this forum: Amazon [Bot], Bing [Bot] and 235 guests
