 Post subject: Zooming in Resolution and Black Screen flickering
PostPosted: Fri Jan 25, 2019 5:23 am
So recently anytime I click an application my resolution will zoom in and flicker a black screen. Sometimes it will resolve its self and go back to my correct resolution, but sometimes it says zoomed in. After uninstalling Winstep/NeXus it stopped the problem. So I want to know why it is happening and how to fix the issue because I really don't want to have to constantly zoom in and out. I do love the NeXus dock, but I can't handle the zooming and flickering anymore.
File comment: Zoomed in screenshot
 Post subject: Re: Zooming in Resolution and Black Screen flickering
PostPosted: Fri Jan 25, 2019 5:33 am
You already asked this question HERE, and I replied to it.
The screenshot you provided makes it very hard to understand what is going on or what the problem actually is. Could also be a video driver problem affecting applications that used layered windows.
PostPosted: Fri Jan 25, 2019 5:43 am
I am not running a magnifier software and the image is hard to see because that is what I see when it zooms in. I can't see anything when it zooms in. Which is why I want it to stop zooming in.
PostPosted: Fri Jan 25, 2019 6:07 am
Here is a screenshot of my settings
File comment: Settings
PostPosted: Fri Jan 25, 2019 6:21 am
What application are you running at the top of the screen?
Also, you mention this only started happening recently, which implies it did not happen before. What applications have you installed recently on your system or what changes have you made to it?
Reason I'm asking is because I know for a fact this has nothing to do directly with Nexus, even if it may seem that way to you now.
PostPosted: Fri Jan 25, 2019 7:11 am
The program at the top is Rainmeter. It doesn't do anything, it is just a skin. It could possibly be a conflict with the dock maybe the dock thinks it is another dock and trying to make room for it. The most recent software I downloaded was league of legends. I talked to their support and they said it may be a conflict with NeXus.
PostPosted: Fri Jan 25, 2019 7:24 am
That's what I think too... some 3rd party software is conflicting with Nexus. Either that or video driver problems.
So, because I can't actually see what is going on in there, try to provide a bit more detailed explanation of what is happening, please... from what I understood, as soon as you click/launch *any* application from the dock a part of the screen magnifies? But it's not the whole screen? What happens to the application you just launched trough Nexus?
PostPosted: Fri Jan 25, 2019 7:35 am
The program will zoom in and out repeatedly. Sometimes it fixes its self and it goes to the correct resolution sometimes it just stays zoomed in and I have to go to my settings and manually change my resolution. I thought it was my magnifier to (something with my mouse maybe) but the magnifier is turned off. I can send a video to show what it looks like.
PostPosted: Fri Jan 25, 2019 8:00 am
Yes please, a video would be terrific! :)
Also, doesn't the Rainmeter taskbar have a magnifier tool as well?
PostPosted: Fri Jan 25, 2019 8:20 am
It won't let me submit the video. I didn't know rainmeter did have a magnifier and I don't know how to check.
PostPosted: Fri Jan 25, 2019 10:42 am
wait, is it a maginfying effect (does it move around your desktop with cursor like windows magnifier) or is it a resolution change?
PostPosted: Fri Jan 25, 2019 11:23 am
No you have to host the video on Youtube or similar.
Then added in the youtube
Code:
[ youtube ][ /youtube ]
tags.
HIH
oOSGearOo Aka Steve....
Technobable
PostPosted: Sun Jan 27, 2019 5:41 am
No it is just the resolution. The resolution will zoom in and out.
PostPosted: Sun Jan 27, 2019 5:53 am
Here is a video I posted to youtube of my computer.
PostPosted: Sun Jan 27, 2019 6:47 am
Wow. That has nothing to do with Nexus anyway.
Here, try reading THIS.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 168 guests
