 Post subject: Grid Stack organization
PostPosted: Wed Jan 30, 2019 6:30 pm
I created a grid stack in the dock and it works fine except for one small quirk-as I add and remove items the stack is resized (rows added/removed) and shifts the items position/location, which means I have to look for an item every time the stack contents shift location. I prefer an items location fixed so I know exactly where to look for it, this is especially useful if I have a bunch of documents in the stack. have default option as current behavior, but also give user flexibility to override and customize so that user can say for example keep 8 items in each row (fixed width) and if adding more than 8 items then stack grows to next row, but if less than 8 items, stack size stays fixed and items are not shifted.
 Post subject: Re: Grid Stack organization
PostPosted: Fri Feb 01, 2019 7:39 am
Apologies for the late reply, had to think about this.
Grid Stacks are supposed to be dynamic in size by their very nature. This said, I understand your request (nothing like muscle memory to get you what you want) so I'll see what I can do.
PostPosted: Sat Feb 09, 2019 1:47 pm
In the next release you will be able to find new Grid size 'Icon Rows' (height) and 'Icons' (width) settings in the Appearance tab of Grid Stack Property panels.
They're set to Auto by default but you will be able to change them to whatever fixed value you want.
PostPosted: Sat Feb 09, 2019 4:28 pm
YEA!! :D
PostPosted: Sun Feb 10, 2019 9:51 pm
Awesome!!
Users browsing this forum: Amazon [Bot], Google [Bot] and 201 guests
