 Post subject: bblean
PostPosted: Tue Sep 21, 2004 8:40 am
i was wondering if enyone knows if there is a way to run bblean and winstep together. when I load up bblean I loose my start button so I cant get the winstep menu. if eny one knows how to do this I would appricate the help thanks.
PostPosted: Tue Sep 21, 2004 9:13 am
ctrl+F12 should call the Nextstart set up screen. From there you may be able to assign new hot spots to the bblean desktop to call your main menu but I am not sure about how to get the start button back. Maybe you could set up a bump screen edge or corner hotspot to call the main menu. :lol:
PostPosted: Tue Sep 21, 2004 4:21 pm
Will someone please enlighten me about what bblean is and why does it seem to hide, according to the above post, the NextSTART startbar/hotspot button(?) ? :D
PostPosted: Wed Sep 22, 2004 5:34 am
It's a windows shell replacement, I've never used it myself.
Users browsing this forum: Amazon [Bot], Google [Bot] and 191 guests
