 Post subject: Need help downloading older version of Winstep Xtreme
PostPosted: Fri Apr 05, 2019 9:59 pm
I purchased Winstep Xtreme a while back and recently I bought a new PC. I don't have the old installer and the email I have only gives me 19.2 but I need 18.x
unfortunately I'm not sure of the exact version. Is there any way I can get the old installer or use the new installer to get back to the version I purchased?
 Post subject: Re: Need help downloading older version of Winstep Xtreme
PostPosted: Fri Apr 05, 2019 10:08 pm
Last version your license key will work with is v18.3. Given the sheer amount of new features since then, I would seriously consider renewing your upgrade subscription if I were you. :P
Anyway, I'll send you the link to v18.3 by PM.
PostPosted: Fri Apr 05, 2019 10:11 pm
I am planning on it, it's not too expensive just don't have the funds right now. I appreciate the help. :D
Users browsing this forum: Bing [Bot] and 123 guests
