 Post subject: windows 10 - 1903
PostPosted: Thu Jun 06, 2019 10:41 pm
I only have nexus ultimate, everything was perfect.
I updated my windows to latest version (1903) and now I do have problems..
Nexus is running in the background (task maanager) but I have no access.
Any idea, what must I do ?
 Post subject: Re: windows 10 - 1903
PostPosted: Fri Jun 07, 2019 5:09 am
As far as I know, there are no problems with 1903.
What happens if you press CTRL+F11 (it should open the Preferences windows of Nexus)?
If nothing happens, try killing the process in the Details tab of the Windows Task Manager and manually running Nexus again. Report back what happens, please.
PostPosted: Fri Jun 07, 2019 5:10 am
I don't know what you have to do to get nexcus up and running. What I will say is that I have had Winstep Extreme running for months in 1903 without fault.
How did you upgrade to 1903?
Was Nexus installed before the upgrade?
What version of Nexus are you running "version number" if you recall it?
Perhaps if its not to full with customizations and skins, try Stopping
nexus from task manager, and reinstall nexus,
either by installing over the top, or uninstalling and reinstalling.
Iam sure Jorge will tell you asap if I am right.
please provide the above information to help Jorge, I am but a humble user/fan of software.
@Edit Jorge u beat me to it
oOSGearOo Aka Steve....
Technobable
PostPosted: Sat Jun 08, 2019 1:27 am
first of all THANK YOU..!
I did exactly as you said..
I stopped the program within task manager and then restart it but same as before..
It begins to run and when you start to work with another program and later want to go back to nexus it is not there (Task Manager: I see it is there and running) but I can not access.
Mein version is 18.12
I tried F11 (even assigned a new key) but nothing happens.
Nexus was there before 1903 and it was running perfect, this began immediately after the upgrade. The upgrade, I did it the normal way, I checked windows update it was there and I just let it go and all done by itself.
The only thing I didnot try is the Uninstall and reinstall which I will do asap.
Thanks again, it was very kind of you..!
PostPosted: Sat Jun 08, 2019 5:56 am
Latest official release is v19.2. Since you are re-installing, try upgrading to that.
Users browsing this forum: Amazon [Bot] and 163 guests
