 Post subject: NEXT START "Window" is away!
PostPosted: Fri Jul 19, 2019 11:27 pm
Hy,
i played with differnt Resolutions on Win 10 and now I miss the NextStart -Dock...
"WIN + TAB" doesent help... ;)
Maybe YOU can help me out..? :-)
 Post subject: Re: NEXT START "Window" is away!
PostPosted: Tue Jul 23, 2019 12:34 am
Have you already rebooted your system?
PostPosted: Tue Jul 23, 2019 2:22 pm
Since I write this post , some times!
I switch on and of both monitors...
Taskmanager Shows Nextstart.. But nothing on the screen...
PostPosted: Tue Jul 23, 2019 3:43 pm
What happens if you press CTRL+F12 ? It should pop up NextSTART's Preferences screen - from there you can double check your configuration. There should also be a NextSTART icon in the systray/notification area that also allows you to access Preferences.
PostPosted: Tue Jul 23, 2019 8:24 pm
THANX!!!!! CTR+F12 worx!
Playing arround with the config and everything is fine again!
Also i make the systray-icon visible, so it may help me, if i forget F12 ._)
Thank You!
PostPosted: Tue Jul 23, 2019 9:23 pm
Glad you got it working again! :)
Users browsing this forum: Majestic-12 [Bot] and 177 guests
