 Post subject: Problem with the Taskbar
PostPosted: Fri Aug 09, 2019 4:31 am
Hello there,
This morning I powered up the Pc and found this strange thing:
The NextStart TaskBar appears a few pixel lower than yesterday, to pop it up I have to bump the upper screen edge as always.
Did nothing particular, just Windows Updates.
Couldn't find anything helpful in the options… tried to reboot a couple of times but didn't help.
Can someone please help me?
Baio
 Post subject: Re: Problem with the Taskbar
PostPosted: Fri Aug 09, 2019 10:29 pm
If you exit Winstep Xtreme and then maximize a window, what do you see?
PostPosted: Fri Aug 09, 2019 11:02 pm
Ok, it was the Windows Taskbar that had lost the "hide" attribute.
Quitted NextSTART, hided the Windows Taskbar and then launched NextSTART again. Now it works correctly.
Thanks.
Baio
Users browsing this forum: No registered users and 199 guests
