 Post subject: Dock shortcut to Windows 10 Settings
PostPosted: Thu Aug 22, 2019 12:23 pm
Wondering if anyone has worked out how to create a dock shortcut to Windows 10 Settings? In the Internal Commands selections there is an entry for the legacy 'Control Panel' but nothing for Windows 10 settings.
Any ideas appreciated.
 Post subject: Re: Dock shortcut to Windows 10 Settings
PostPosted: Thu Aug 22, 2019 2:53 pm
Since Windows 10 settings is a UWP app, here is the best/quickest way:
1. Set the dock to show running applications.
2. Open the Windows 10 settings panel from the Windows Start Menu
3. Right click the new Settings icon in the dock and select 'Pin to Dock'
4. Bob's your uncle.
I'll add access to the Windows 10 settings panel via an internal command for next release.
PostPosted: Wed Sep 18, 2019 8:34 am
Perfect, thank you!
Users browsing this forum: No registered users and 187 guests
