 Post subject: Theme fixing (updating)
PostPosted: Sat Nov 23, 2019 8:14 pm
Hello to all,
I would like to fix the most jarring problems with this skin
https://www.wincustomize.com/explore/winstep/451/
Most disturbing I find the streching and misalignment in shelfs, example below:
vs normal, no streched
 Post subject: Re: Theme fixing (updating)
PostPosted: Sun Nov 24, 2019 8:06 pm
Actually this would be the correct skin:
If anyone could tell me what files do I need to modify to fix this...
PostPosted: Mon Nov 25, 2019 2:37 am
WebGizmos didn't properly set up the non-stretchable edges of the Shelf body bitmap. I fixed it, download the attached zip file and extract Prowler2.wsw into the proper theme folder, replacing the old file there.
You will then need to apply another theme and only then re-apply Prowler2 for the changes to take effect.
Prowler2.zip [793 Bytes]
Downloaded 1217 times
PostPosted: Mon Nov 25, 2019 12:33 pm
Thx Jorge, it works great. I did some fiddle with the fonts color, had some ugly white stroke around the text in the workshelf, got rid of that with the "TextEffectColor=3".
Btw,it seems that the controls over the fonts from the interface (Preferences/Themes/Fonts) have no effect... Maybe there is a bug there.
PostPosted: Mon Nov 25, 2019 4:44 pm
Already been fixed here for next release... had to do with the fact that you now can have multiple shelves (while before you could only have one) and each shelf can have a different theme.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 248 guests
