 Post subject: Workshelf not going to the top of screen.
PostPosted: Tue Mar 31, 2020 12:50 pm
Ok this is a strange one. When I choose which screen edge to attach to for the shelf and say top... it goes to the bottom. Bottom also goes to bottom.
I turned off Display Fusion to be safe and that's not it.
Tried setting some space reservation from NextStart properties as well. No luck.
 Post subject: Re: Workshelf not going to the top of screen.
PostPosted: Tue Mar 31, 2020 7:55 pm
Either upgrade to the v20.3 beta (check the 'notify me of beta (test) versions' in the Advanced tab of Preferences) or DO NOT use the Shelf Properties panel to set the location of the Shelf - there is a bug in v19.2 that prevents it from working properly (and has been fixed in v20.3).
Alternatively in v19.2 you can either use the Docks & Shelves tab in Preferences OR the right click context menus to position the Shelf.
PostPosted: Tue Mar 31, 2020 8:42 pm
Yeah that did the trick (right click setting). Thanks.
Is the spacing/gap between a maximized window and a shelf set from the properties of the skin by chance? I can see a pretty good sized pixel gap between the two when maximized and I want to change that.
PostPosted: Tue Mar 31, 2020 9:05 pm
It's the skin - some skins have a large semi-transparent gap in the bitmap for drop shadows, etc...
Open the Shelf Properties dialog -> Position tab -> Advanced button -> play with the offset.
PostPosted: Tue Mar 31, 2020 9:15 pm
Ugh. I was looking for that very thing but not the right place. That's why I asked if it was controlled in the theme. Was ready to jump into those theme files haha.
PostPosted: Tue Mar 31, 2020 9:27 pm
Eheh. Not the type of setting you would use everyday, so it's kind of buried.
PostPosted: Tue Mar 31, 2020 9:31 pm
The support is great here. I really appreciate your constant attention to the users (i be stalking the other posts 8) )
I am interested in making my own themes but I have seen no theme editor (well, there is an early alpha that I opened, that lead down a hole of fixing my creative cloud install), and of course no documentation. It's the old trial and error route it looks like.
Having looked inside a couple of files it "looks" fairly straightforward but looks can be deceiving.
PostPosted: Thu Apr 02, 2020 7:29 pm
Wolfen wrote:
TI am interested in making my own themes but I have seen no theme editor (well, there is an early alpha that I opened, that lead down a hole of fixing my creative cloud install), and of course no documentation. It's the old trial and error route it looks like.
Oh, man, you jinxed it! Now we have to wait ANOTHER 7 years. ;-) (just kidding Jorge)
PostPosted: Fri Apr 03, 2020 3:36 am
Too late, he jinxed it. Sayonara! lol
PostPosted: Fri Apr 03, 2020 4:58 am
Aww man. I didn't know the rules to the game!
PostPosted: Sat Apr 04, 2020 7:49 am
No one knows the rules. Not even Jorge.
I think he wrote them down once but threw them in the fire just to show us how cool he was.
PostPosted: Sat Apr 04, 2020 7:51 am
:lol: :lol: :lol:
Users browsing this forum: Amazon [Bot], Google [Bot] and 185 guests
