 Post subject: Different docks on different virtual desktops
PostPosted: Thu May 07, 2020 1:40 pm
Is that possible to have dock #1 showing only on 1st virtual desktop, and the dock #1 only on 2nd virtual desktop?
Under virtual desktops I mean those you can create in Win10 via Win+Tab hotkey
Maybe with the help of some command line params
Or maybe it's possible to run two copies of Nexus Ultimate with different profiles
 Post subject: Re: Different docks on different virtual desktops
PostPosted: Thu May 07, 2020 2:02 pm
Winstep applications only run single instance and that is by design.
I never gave a proper look at the Windows 10 VDM (I don't even use it as I run a 3 monitor system) so for the time being there is no setting associated to it.
That might change in the future though, since VDs are now a part of the OS (while before 3rd party VDM solutions each implemented things their own way, etc...)
PostPosted: Thu May 07, 2020 5:45 pm
Thnx 4 the answer,
the thing is when I'm work from home because of coronavirus I prefer to keep all work stuff and icons of my work soft on a separate desktop, even if I have 2-3 monitors
So I can switch fast from work to my usual personal home PC condition completely, would be great to support VDM in future yeah!
PostPosted: Thu May 07, 2020 6:54 pm
No worries, I will eventually look into that. Just don't ask me when. :)
Users browsing this forum: Amazon [Bot], Google [Bot], ppetroff60 and 187 guests
