 Post subject: Function differences between Nexus Ultimate and Xtreme
PostPosted: Tue May 26, 2020 11:49 pm
Since I will have to purchase a new license [because of an MS windows disaster lost my original install license] I am unable to simply annually update, because after fixing the windows problem it annihilated my full license of Nexus Ultimate.
Now being at a crossroad, I would appreciate if I can get some pointers of the most significant difference of Xtreme. I see the visual difference and know that WinStep is fantastic with visual customization possibilities.
What I need to know is what changes in the functions?
I am contemplating to maybe go for the Xtreme this time since I have to start from scratch. Will the backup that I have saved from Ultimate work without too many modifications in Xtreme.
screenshot 1 = using docks etc. individually as my own navigation system throughout my hard drives.
screenshot 2 = as my desktop looks always hiding the docks and activating via edge bump, closing auto after selection of an item was made.
I truly appreciate any feedback. :?
Thanks, Michele
 Post subject: Re: Function differences between Nexus Ultimate and Xtreme
PostPosted: Wed May 27, 2020 3:18 pm
Thanks, Michele
If you ask Jorge(winstep) nicely he will provided you the licence codes again.
oOSGearOo Aka Steve....
Technobable
PostPosted: Wed May 27, 2020 11:31 pm
Hey Michelle,
Just moved offices so things are still a bit hectic here - and I'm trying to catch up with old(er) email.
PostPosted: Sun May 31, 2020 4:38 am
Hey Michelle,
Oh, Dear, I know what this is like. I just wanted you to know, I was able to resolve the trial issue. Did a rigorous search [hours - lol] on all my hard drives, and voila, I found one of the very early [from 2010] installation saves [key] and I simply dropped it in the license folder, and bingo, it immediately changed me to registered [again].
After you have time - no rush] I may still consider purchasing a Xtreme version.
I wish you smooth sailing :roll: with setting up all your equipment all over again!
Kind regards,
Michele
Users browsing this forum: Google [Bot] and 198 guests
