 Post subject: Is there a way to show all open browser tabs from the dock?
PostPosted: Fri Aug 07, 2020 1:23 am
On the windows task bar when you have multiple tabs opened in say Chrome you can hover over the icon and it will show you a small window with all the tabs you have opened, is there a function similar to this on the dock? I have 3 monitors and move tabs across all the screens, currently on my dock if I just click my chrome icon it opens the last tab I used. I have to alt tab through all my opened programs to find the tab I want to bring up.
 Post subject: Re: Is there a way to show all open browser tabs from the do
PostPosted: Fri Aug 07, 2020 1:55 am
Chrome is a queer sort of beast. You might get the tabs displayed when you hover over the icon in the NextSTART Taskbar, but I don't think there's any way to have this in NeXus. You do know that Chrome = Google and that you're gifting Google all your data - pages looked at, browser version, OS, geo location, etc. etc. There's no privacy there at all, nor security.
PostPosted: Fri Aug 07, 2020 6:17 am
Did you already enable the 'show running applications on this dock' setting?
PostPosted: Fri Aug 07, 2020 4:29 pm
Thank you both for the replies and thanks Winstep that is what im looking for, its not perfect but im very happy to use it.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 167 guests
