 Post subject: Adding a Windows 10 App to Nexus
PostPosted: Fri Aug 23, 2019 3:18 pm
Hi!
I was trying to add the Windows 10 OneNote app to Nexus and kept running into issues. I read through the forums here and I see I could make a shortcut and add the shortcut - but that seemed like a kludge rather than an answer. After experimentation and research, here's how I did it - and it should work for any 'App'.
1) Open up Windows Powershell as administrator.
2) In Powershell, run
Code:
get-appxpackage > c:\apps.txt
a) You can name the file whatever you want and place it at any convenient location
3) Open up the txt file you just made, and search for the application you are looking for
a) In my case, it was OneNote
b) Bear in mind, you might have to search through the list if the AppName isn't similar to the display name
4) Make note of the 'PackageFamilyName' and 'InstallLocation'
a) Don't close the file, you'll need it in a minute
5) In Powershell, change directory to the 'InstallLocation' you found in step 4
a) cd <installLocation> where you replace <installLocation> with 'InstallLocation' from step 4
6) In Powershell, run
Code:
explorer .
7) Windows File Explorer should open in the directory of the App. Open the file labelled 'AppxManifest.xml' with your favorite text editor
8) In your favorite text editor, search for Executable.
9) Note the Id parameter in the Application XML field (same line as Executable)
10) Create your Nexus dock item. Under the properties, in the filename text box, enter
Code:
shell:appsFolder\<PackageFamilyName>!<Id>
where you copy and paste the PackageFamilyName from the txt file in Step 4 and Id from the parameter in Step 9
11) [Optional] To change the icon to the one for the App, choose 'Change Icon' and choose Browse. Cut the path from the 'InstallLocation' and go to that directory. There should be an 'Images' sub-directory which should contain the PNG file for the App.
Happy Docking!
 Post subject: Re: Adding a Windows 10 App to Nexus
PostPosted: Sat Aug 24, 2019 2:37 am
Thanks. And for those not savvy enough to work with Powershell, etc, simply open the Windows Start Menu and drag the UWP app from the Windows Start Menu into the dock. No need to create a shortcut first.
Alternatively, if you are running Nexus Ultimate or Winstep Xtreme, the default Shelf has a default tab named 'Apps', which holds all the installed UWP apps on your system. Either use that tab to launch a UWP app or drag items you want from it into other docks, etc...
PostPosted: Mon Aug 17, 2020 3:26 pm
I have tried both of the methods. I used the powershell and opened the text file, but not all apps were there(I looked through all of them). I tried just dragging the apps from the start menu, but it did not work. it didn't have a file name and it was a virtual application.
PostPosted: Mon Aug 17, 2020 4:01 pm
What version of Nexus are you running?
What language is your Windows 10 in?
Can you please post a screenshot of the Item Properties dialog for one of the UWP apps you dragged from the Start Menu into the dock?
PostPosted: Tue Aug 18, 2020 2:10 am
FYI, you can access ALL apps UWP's and Desktop apps without the PowerShell. Just go to "Run" (WINKEY "R") and enter…
Code:
shell:appsfolder
You'll get the whole kit and kaboodle as icons to drag to the dock.
P.S.
Jorge, good to see you're still with us. I was afraid you had succumbed to Covid 19.
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
Users browsing this forum: Amazon [Bot] and 192 guests
