 Post subject: Reduce Gap Between Shelf and Edge
PostPosted: Tue Sep 22, 2020 8:32 pm
As the title states there is a gap between the shelf and the monitor edge, at the moment I have it at the top of the screen but it dosnt matter which edge I use there is always a gap, is there a way to reduce this gap? please see screenshot.
 Post subject: Re: Reduce Gap Between Shelf and Edge
PostPosted: Sat Sep 26, 2020 3:49 pm
Anyone?
PostPosted: Mon Sep 28, 2020 12:11 am
I believe the gaps are determined by the theme itself...usually for blending or shadow effects.
PostPosted: Tue Sep 29, 2020 5:47 pm
OK thanks. Most of the themes I tried leave a gap of varying sizes, would be nice to over-ride the gap.
Users browsing this forum: Amazon [Bot], Google [Bot], ppetroff60 and 180 guests
