 Post subject: Black Label box remove
PostPosted: Mon Oct 19, 2020 11:23 pm
Hey Guys, is there a way to remove the black label box completely when I hover my mouse on my items in my dock?
The picture shows the black label box:
Thanks :D
File comment: The label
 Post subject: Re: Black Label box remove
PostPosted: Tue Oct 20, 2020 3:58 am
Does this option help?
PostPosted: Wed Oct 21, 2020 2:04 pm
Nope, its does not :( I can´t find a setting to remove it.
PostPosted: Wed Oct 21, 2020 2:58 pm
You must use that in combination with your windows settings:
1. Right-click on the Start menu.
2. Choose Control Panel then, click Ease of Access.
3. Click Change how your mouse works.
4. Look for Make it easier to manage windows then, uncheck the box beside the Activate
a window by hovering it with the mouse.
5. Click Apply, then OK.
PostPosted: Thu Oct 22, 2020 9:22 pm
I tried that, still doesn't work :( , but thanks for the help 8)
PostPosted: Fri Oct 23, 2020 2:23 am
Can you post a screenshot of this window (below) and then the window that shows up when you click "Label Settings"?
PostPosted: Wed Oct 28, 2020 7:22 am
That actually looks like the balloon tooltip, not the label, although I have no idea why it's empty.
In that case, assuming he is running the free version of Nexus, Preferences (or Dock Properties panel for that dock if running Ultimate or Xtreme) -> Behavior tab -> More Options -> Set 'Show ballon information tooltips...' to Never.
Users browsing this forum: No registered users and 224 guests
