 Post subject: Icon module size?
PostPosted: Sat Nov 28, 2020 6:11 pm
Hi. I'm new to Nexus dock and started to build my own theme. I'm not yet familiar with the possibilities and impossibilities + I'm a bit lazy to search so I'm using Windows10nx theme as a base.
The dock will be vertical and on the right side. I have made rectangle shaped icons and found out that I can't set the icons enough close to each other, so there's quite big gap between them. I opened the .nxs file to find out is there any possibilities to adjust the icon module size. And that's my question: Is there a way to edit the icon module's form from square to rectangle?
 Post subject: Re: Icon module size?
PostPosted: Sat Nov 28, 2020 8:51 pm
i think all icons are square sized, dock or windows both, rectacle or round ones simply have translucent space
Users browsing this forum: Amazon [Bot], Google [Bot] and 185 guests
