 Post subject: Disable grouped icon menu
PostPosted: Wed Dec 02, 2020 4:56 pm
I want to disable the grouped icon menu
This is the menu I'm talking about:
I just want a window to show up when I click an icon, that's it.
PS:
I tried reaching out through e-mail for about a month now, but I haven't received a single reply.
 Post subject: Re: Disable grouped icon menu
PostPosted: Wed Dec 02, 2020 5:53 pm
If you are talking about the NextSTART taskbar
Press CTRL-F12 or right-click the taskbar and choose Preferences. In the Preferences window, switch to the "Taskbar" tab, click "Tasklist Settings" and then change your task "Grouping" settings.
PostPosted: Wed Dec 02, 2020 6:55 pm
Thank you!
Forgive me for forgetting to specify.
I was talking about Nexus Ultimate.
Your tip works pretty much the same for Nexus Ultimate.
This does indeed work to get rid of the grouped menu, however I would really like to keep the app grouping, I just don't want to see the menu when I click on an icon. It should just open the app for me.
Any ideas how to reach this result?
PostPosted: Wed Dec 02, 2020 7:42 pm
I have mine grouped and then I hover to let it show me thumbnails of the windows. I then click the thumbnail of the window I want to bring to the front. (This is assuming I don't use Alt-Tab or Windows-Tab to select my window.)
Also, note, I'm using NextSTART's taskbar and don't use the dock as anything except a launcher, so I don't switch windows in the dock. That's just my preference, not a statement of who is doing things right or wrong. :-)
PostPosted: Wed Dec 02, 2020 7:58 pm
I see. I tried it for a bit, but that setup doesn't really work that well for me. It still adds another click in between launching.
It looks like there's an option that does precisely what I want:
However this option doesn't do anything for me at all. Disabled or enabled.
PostPosted: Wed Dec 09, 2020 4:21 pm
Anyone else here with an idea?
I tried reaching out to developer through email for more than a month, but I'm being ignored.
Users browsing this forum: Amazon [Bot], Google [Bot] and 164 guests
