 Post subject: What Makes Shark Navigator Lift-away Bagless Upright Vacuum
PostPosted: Thu Jan 07, 2021 12:52 pm
So, you are thinking about getting a new vacuum cleaner for your beloved house. You would like to fall for a model that delivers strong suction power to pick up the most stubborn debris and dirt, but at the same time, you want it to be small enough to reach tight places. It sounds a little bit demanding, right? But it is actually not!
You do not need to browse various websites to find it out - what you need is just TheKingLive. At our site, we commit to fully support our readers in making the right purchase decision by providing reliable reviews, great recommendations and hot deals.
We spend hours checking product reviews and ratings on e-commerce sites as well as testing in the lab before each review is posted, ensuring that every minute of reading is worth it! And for today's topic, we would like to introduce you to the Shark Navigator Lift-Away Bagless Upright Vacuum.
What is great about this vacuum?
As its name suggests, Shark Lift Away Vacuum Cleaner is a 2-in-1 vacuum that meets your requirements. You can use it as an upright vacuum or as a stick vacuum but with a detached canister to reach into tight places. It is also a great choice for allergy sufferers as it is equipped with Complete Seal Technology and a HEPA filter that can trap up to 99% of allergens in the air, providing a healthier environment for users.
1. Power and Versatility
After reading numerous Shark Navigator Lift-Away Vacuum Reviews as well as performing tasks in the lab, we are confident to say that the device works extremely well on both high-pile and low-pile carpets, pretty well on bare floors and hardwood floors. The result for carpets is impressive at the first pass as it can remove nearly 100% pet hair and small debris.
For big debris on carpets, you might need multiple passes, but it is not considered a problem as it is also the situation with almost all other vacuums. In case of bare floors and hardwood floors, the vacuum can pick up 60% - 80% of dirt, but to completely clean the floors, especially when it is full of large debris, you may need up to five passes.
When the canister is detached from the Shark Navigator Lift Away, users can easily clean other areas like stairs, corners, and ceilings. For some hard-to-reach places like window sills, furniture ledges, and lampshades, a crevice tool, an upholstery tool, and a dusting brush are necessary to get the work done.
2. Design
In general, the vacuum’s design is good. This Shark vacuum has three cleaning modes, “I” for bare floors, “II” for carpets, and detached canister model, all in one so pretty convenient. Another advantage of the vacuum is its high-capacity dust cup of 2.2 dry quarts, meaning you do not need to empty the cup while doing your cleaning.
However, this does come with a disadvantage as it makes the vacuum heavier by approximately 13.7 pounds in upright mode and 9 pounds in handheld mode. Also, its power cord of 25 feet is a little bit short compared to other Shark vacuums.
3. Price
At only $200.00, it can be said that this Shark Navigator Lift Away Vacuum Cleaner is a bargain for such good quality. As a mid-range vacuum, it lacks some features compared to premium models.
However, it should be more than enough to cover ordinary needs such as cleaning carpets, bare floors, hardwood floors, inside the car, and some tight areas such as corners, under furniture and stairs. What more can you expect from such an affordable vacuum?
4. Assembly
Another great point of this Shark Navigator Lift Away Upright Vacuum is its simple setup process. After unboxing, you can get the vacuum put together in less than ten minutes. Although its instructions are easy to follow, it is recommended that you search for a YouTube video to get things done quicker and easier.
Comparison
If you are willing to spend more:
Paying a little more can bring more satisfaction to users. With a budget of around $300.00, you will be able to opt for the Shark APEX Upright Vacuum with DuoClean AZ1002, a more innovative model that allows you to go under low furniture smoothly.
This vacuum can also maintain its full suction power when the canister is detached so you may not need extra tools to go clean tight places. It does offer a self-cleaning feature which automatically removes dirt and hair stuck in the brush roll.
If you would like to spend less:
With the same powerful cleaning features to our Shark Navigator Lift Away Upright Vacuum, the Shark Navigator Upright Vacuum NV352 is a more affordable model. This vacuum delivers quite the same suction power as the Shark Navigator Lift Away.
It also has three settings for different surfaces and is equipped with all necessary tools for better cleaning. What makes its price lower to the recommended model is a small dust cup capacity and a shorter power cord, meaning it is trickier to maneuver. However, these will not be disadvantageous if you are living in a small apartment.
✪✪✪ Picked For You: Best Shark Navigator Lift Away - Review and buying guide
The Bottom Line
We hope that the information provided here can somehow help you in making your purchase decision. Share your opinions and experience of using vacuums with us, such as what you like, what you do not like about your current vacuum, and what you expect from a vacuum cleaner. Those will be great clues for us to develop our next posts as well as suggesting more suitable products to you - our readers.
In case you would like to read more Shark Navigator Lift Away Reviews or other product reviews, remember that you can always find them on our site. We do not just provide reviews on vacuum cleaners, we do reviews about multiple household appliances and products such as hiking boots, hiking pants, coolers, pocket knives and so on. Just come and explore!
 Post subject: Re: About WinStep extreme custom installation
PostPosted: Thu Jan 07, 2021 5:08 pm
jamesmustain wrote:
Hi, with last version 18.12 during installation of winstep extreme i can seletc which products install or not ?
Thanks!
18.12? Have you got hold of some 'warez' version? It's certainly not anything like the last version. Move on and buy a legit one - unless that is what you have.
PostPosted: Thu Jan 07, 2021 9:50 pm
Most of us are running the 20.10 version. I don't recall if 18.2 allows you to install select pieces of the product.
Users browsing this forum: Amazon [Bot], Google [Bot] and 178 guests
