 Post subject: I can't locate the BUY button
PostPosted: Fri Jan 08, 2021 5:07 pm
Hi,
I desperately search for the BUY button on the site. I go to products, chose WinStep Extreme, click on Buy Now, but on the next page there is no BUY button, so I have no idea how I am supposed to buy it??
 Post subject: Re: I can't locate the BUY button
PostPosted: Fri Jan 08, 2021 5:32 pm
DeadVoivod wrote:
Hi,
Each of the options for different versions has an "Add to cart" button.
Get paranoid FFS!
PostPosted: Fri Jan 08, 2021 5:45 pm
I click this button:
Then I get this page, but no BUY button or ADD TO CART
PostPosted: Fri Jan 08, 2021 7:46 pm
Your ad-blocker is blocking the "Add to cart" button. It's doing that because the button takes you directly to another site (bmtmicro.com), so the ad-blocker generically thinks it could be an ad instead of a legitimate button.
PostPosted: Fri Jan 08, 2021 8:44 pm
Indeed, it was the AdBlocker.
Thanks a lot.
PostPosted: Fri Jan 15, 2021 9:47 pm
WOW. I would never have known this could be a thing.
What a stupid 'feature', if only because the user would only click the button if he wants to.
This said, I run AdBlocker under Firefox and it doesn't do that here.
PostPosted: Sat Jan 16, 2021 1:22 am
I'm now running Brave (I wasn't when I wrote the reply above). By default, it's blocking your "Add to Cart" buttons, too.
When I wrote the reply, I was running Microsoft Edge with uBlock installed.
PostPosted: Sat Jan 16, 2021 2:52 am
Ok, thanks for the heads up.
I added a blue "NOTE: please disable your ad-blocker if you cannot see the Add to Cart buttons below." line to the top of the Buy Now pages.
Hope that alleviates the issue since there is nothing I can do to actually fix it. This is REALLY REALLY stupid, buttons are not adverts.
PostPosted: Sat Jan 16, 2021 5:09 am
Code:
<a href="https://secure.bmtmicro.com/servlets/Orders.ShoppingCart?CID=493&amp;PRODUCTID=4930001&amp;CLR" title="Add to cart Winstep Xtreme" class="button green">Add to Cart</a>
I thought maybe you meant form buttons, but they are just straight links. You realize that the most basic of advertisements looks just like this?
Code:
<a href="https://some.other.site.that.is.not.this.site.com/shopping/cart/in/url">With an Add to Cart Text</a>
PostPosted: Sat Jan 16, 2021 5:17 am
WWW = World Wide Web. If you kill all external links it's not a web anymore, much less worldwide. :D
Imagine if ad-blocks did the same to the Google Search engine lol All the text and none of the site links :lol:
PostPosted: Sat Jan 16, 2021 7:50 pm
Oh, for Pete's sake, the would, of course, have Google whitelisted.
If you don't want ads blocked, don't use an ad-blocker. If you do want ads blocked, the user needs be willing to understand that some less-well-known sites may not already be whitelisted.
I was challenging your assertion that your standard links pointing to another site with sales-related verbiage does not look like an ad. To an ad-blocker, it looks like an ad.
PostPosted: Wed Jan 27, 2021 12:49 pm
Ric, BMT Micro asked all vendors to change the links because of the issues with uBlock (and also a problem with Chrome).
Can you please check that the Buy Now buttons now appear correctly even with uBlock turned on, please?
PostPosted: Wed Jan 27, 2021 2:52 pm
Brave (all privacy features turned on as by default) and Microsoft Edge with uBlock look fine. Here's Edge with uBlock:
PostPosted: Wed Jan 27, 2021 4:21 pm
Thank you, kind sir. :D
Users browsing this forum: Amazon [Bot], GPT [Bot], ppetroff60 and 145 guests
