 Post subject: 3rd party start button
PostPosted: Tue Feb 09, 2021 3:22 pm
I hate Windows 10 Start Button. I use a 3rd party program that brings back the Windows 7 Start Button. I own Winstep Extreme and want the start button for Stardock Start 10 on my dock. I can not find a way to get the start button on the dock. I do have the Windows 10 Start button on my doc, but want Stardock Start 10 in it's place. How do I do this?
 Post subject: Re: 3rd party start button
PostPosted: Tue Feb 09, 2021 6:12 pm
If you right-click the icon in your dock and click Dock Entry Properties, you can change the Icon Path at the bottom to any icon you wish. Clicking the Change Icon button will let you browse your way to the file you want to use as the icon.
PostPosted: Thu Feb 11, 2021 4:58 pm
I have tried that. I want Stardock Start 10 and that is not an option when I click the dropdown. I looked in the Start 10 folder and do not find a shortcut that opens the Start 10 start menu. I even tried with Classic Shell and could not get this to work. I do not like the way Winstep start menu works. I would like one that I can use the scroll wheel on my mouse to locate a program to run.
Users browsing this forum: Google [Bot] and 196 guests
