 Post subject: Weather icon not changing to reflect weather conditions
PostPosted: Thu Feb 25, 2021 4:28 pm
I have Nexus Ultimate and have an issue with the weather module. It auto-detects the location and retrieves the weather hourly without a problem. However the icon displayed is the full moon and never changes. I checked that all of the icons are present in these folders:
C:\Users\Public\Documents\Winstep\Weather\Icons1\ C:\Users\Public\Documents\Winstep\Weather\Icons2\
I can view these icons with my image viewer and they display properly. Any ideas about how I can fix this will be appreciated. Thank you!
 Post subject: Re: Weather icon not changing to reflect weather conditions
PostPosted: Fri Feb 26, 2021 6:34 pm
Which version are you running?
PostPosted: Sat Feb 27, 2021 3:03 pm
I'm running v20.10
PostPosted: Sat Mar 13, 2021 3:27 pm
As I noted I'm running the latest ie v20.10
Can you suggest a way that I can remedy the icon display issue? Thanks.
PostPosted: Mon Mar 15, 2021 3:23 am
I'm sorry I don't have an answer. This is the most recent discussion of this issue I could find.
viewtopic.php?f=2&t=11468&p=39472
It doesn't appear to have been solved.
PostPosted: Mon Mar 15, 2021 1:48 pm
Thanks for the link. Apparently it's not an isolated problem. Do you know if the developer is aware of it? Hopefully there will be an update eventually...
Users browsing this forum: GPT [Bot] and 155 guests
