 Post subject: Switch off menu transparency?
PostPosted: Wed Mar 17, 2021 1:51 pm
Hello,
I use the Nexus Dock freeware version which is a fantastic program!
Unfortunately, the menus (Folder Menus, Context Menus, ...) are TRANSPARENT which makes them difficult to read. How can I switch OFF the menu transparency?
 Post subject: Re: Switch off menu transparency?
PostPosted: Wed Mar 17, 2021 5:16 pm
Who actually invented transparent menus? They are as unnecessary as a goiter, so to speak!
PostPosted: Thu Mar 18, 2021 3:26 am
PeterPanino wrote:
Hello,
Menu transparency is set by the theme - the actual GFX files are transparent or translucent, and this cannot be changed by the user. Use a theme that does not use transparency.
Even the Windows start menu uses some translucency, incidentally.
PostPosted: Thu Mar 18, 2021 3:03 pm
I need a theme where the menus are not transparent and where the theme does not have any fancy visual play accessories like dragons or cats or any other not-functional attachments. I need to WORK with the dock and not play with it.
Could you indicate to me such a theme? I have gone through the list of themes in Nexus, but all of them seem to be made for game-players.
PostPosted: Thu Mar 18, 2021 3:22 pm
I have now downloaded and imported the "Office" theme from https://www.wincustomize.com/explore/winstep/843/
But it also has the SAME transparent menus!
PostPosted: Thu Mar 18, 2021 3:49 pm
atmospherica has ok menus
PostPosted: Thu Mar 18, 2021 6:08 pm
Do you have a link?
PostPosted: Thu Mar 18, 2021 6:13 pm
Do you have a link?
sorry, dont hye a link, i think its part of nexus ultimate
PostPosted: Thu Mar 18, 2021 6:17 pm
This also has the same transparent menus:
It seems that the menu transparency is common to all skins. All skins I have tried have the same transparent menus!
PostPosted: Thu Mar 18, 2021 6:24 pm
Do you have a link?
but from the link you provided it seems 'office' should have simmilar menus like atmospherica. maybe there is setting somewhere we are missing or a bug. could you screenshot your menus?
PostPosted: Thu Mar 18, 2021 6:32 pm
are you using some 3rd poarty software for windows transparency/aero glass?
this isnt what it looks like at my system
PostPosted: Thu Mar 18, 2021 9:17 pm
No. I have Windows 10 x64. And NONE of my other applications has transparent menus. Nexus Dock is the only one that has transparent menus.
PostPosted: Fri Mar 19, 2021 12:12 am
Hi Peter,
What menu is that? If you're not sure what to call it, describe the steps you use to make that menu appear.
PostPosted: Fri Mar 19, 2021 8:48 am
DesertDwarf wrote:
Hi Peter,
It is a FOLDER MENU: Drag a folder containing links to programs or documents from Windows File Explorer to the Nexus Dock to create a FOLDER ICON:
Then click on the FOLDER ICON to open the FOLDER MENU:
This screenshot of a FOLDER MENU shows also another annoyance: The FOLDER MENU also shows the invisible system files like desktop.ini, setup.ini, and tlbdata.xml.
The FOLDER MENU should of course HIDE those invisible files.
(BTW, tlbdata.xml is a configuration file of another dock product I have tried before. These invisible files are normally HIDDEN in Windows File Explorer. To create the screenshot, they have been made visible only inside a special program)
PostPosted: Fri Mar 19, 2021 11:38 pm
I don't know of a way to fix either problem.
It appears to get menu transparency from the theme images (PNGs) themselves, but I'm not sure which one defines the backgrounds of the menus.
I don't think Jorge provides any means of filtering files, but that's a pretty good idea.
I apologize for not being much help. Hopefully, Jorge will be back from his hiatus soon and can respond.
Users browsing this forum: Google [Bot] and 228 guests
