 Post subject: Is there a calendar widget?
PostPosted: Wed Mar 03, 2021 2:29 pm
Is there a calendar widget for winstep?
 Post subject: Re: Is there a calendar widget?
PostPosted: Wed Mar 03, 2021 10:22 pm
If you mean a module, then yes, there is. But desktop ones are supported only under Winstep Xtreme.
PostPosted: Sun Mar 07, 2021 3:53 pm
I have extreme and can you let me know where I can find a calendar widget or module? If you have a link that would be good or if you can tell me exactly where I can get one it would be appreciated.
PostPosted: Sun Mar 07, 2021 5:29 pm
PostPosted: Mon Mar 08, 2021 1:27 am
Ah. I see what you did there, Seeker. 8)
PostPosted: Sun Apr 04, 2021 10:22 pm
Thanks Seeker, that's exactly what I was looking for.
-CK
PostPosted: Mon Apr 12, 2021 1:07 pm
Oh, great thanks! I didn't see this before. :oops:
Users browsing this forum: No registered users and 212 guests
