 Post subject: Opening Chrome with Google Hangouts open
PostPosted: Tue May 18, 2021 3:47 pm
Basically, I have Google Hangouts open all the time. Sometimes, it's the only Chrome window that's open. When it is, and no other Chrome windows are open, all that happens when I click a Chrome icon to load up the full browser, is that the Google Hangouts window opens and closes. The full browser doesn't come up. I have to close Google Hangouts first, then it works.
Ideas?
::: smellhole
::: It's better to have loved and lost than to never have had a good pair of speakers.
 Post subject: Re: Opening Chrome with Google Hangouts open
PostPosted: Fri May 21, 2021 12:02 am
Are you clicking on it in a Dock or a Shelf?
PostPosted: Fri May 21, 2021 12:07 am
Both, actually. It does this either way. :(
::: smellhole
PostPosted: Fri May 21, 2021 11:55 am
If you arent using hangouts for calls but rather just for IM i would recommend using pidgin rather than chrome, it supports hangouts protocol
PostPosted: Fri May 21, 2021 2:02 pm
Ok, thanks. I will give that a go.
::: smellhole
PostPosted: Fri May 21, 2021 2:44 pm
Well, that took some technical noodling, but I got it to work. Thanks again.
::: smellhole
Users browsing this forum: Google [Bot] and 198 guests
