 Post subject: Disable Windows TaskBar
PostPosted: Sat May 22, 2021 6:47 pm
For me Windows TaskBar is a huge detractor to using NexusDock is there a way to disable it?
Dawson
 Post subject: Re: Disable Windows TaskBar
PostPosted: Sat May 22, 2021 8:38 pm
Dawson
It's in Preferences -> General. :)
PostPosted: Sun May 23, 2021 1:08 am
Yes that I know but the only option available to me is to turn on auto hide. The option to turn off on all monitors is always greyed out. So essentially it's still there.
PostPosted: Sun May 23, 2021 8:41 pm
Hmm, very odd. Never seen that here - When I do run Win 10 and Winstep, I usually use a large second monitor and just copy the laptop's display as I don't really use that then, but never have had any problems, touch wood. I'll try and think about this problem but hope also that someone else might be able to help?
Users browsing this forum: Google [Bot] and 205 guests
