 Post subject: Date/Time font size
PostPosted: Mon May 24, 2021 4:00 pm
Is there a way to increase the font size of the Date/Time in the system tray? I have a 4K monitor and the font is teeny-tiny.
::: smellhole
::: It's better to have loved and lost than to never have had a good pair of speakers.
 Post subject: Re: Date/Time font size
PostPosted: Mon May 24, 2021 7:07 pm
I use T-Clock, its free and fully customisable.
https://github.com/White-Tiger/T-Clock/
PostPosted: Mon May 24, 2021 7:33 pm
Thanks, but I tend to stay away from software that requires a bunch of research just to figure out how to use. That looks horribly complicated.
I appreciate the effort, though.
[edit]
And sadly it doesn't seem to run on my win10 system. The x64 version locks everything up and I had to reboot. and the 32bit version doesn't display anything anywhere.
Is the supposed to run with NextSTART?
Alas.
[/edit]
::: smellhole
PostPosted: Tue May 25, 2021 2:39 pm
[edit]
Alas.
[/edit]
I'm sure the topic of T-Clock / Tiny Clock has come up before - have a search for it, there may be answers there.
Other than that, the Windows system tray clock is ludicrously tiny even on smaller resolutions and of course NexSTART cannot change that. That's why I've never used it myself. I would use the Winstep clock module if you want a clock in the taskbar.
Users browsing this forum: Amazon [Bot], Google [Bot], ppetroff60 and 182 guests
