 Post subject: How to add the windows language bar to the taskbar - SOLVED
PostPosted: Wed Sep 29, 2021 12:05 pm
Hello.
I'm sorry if it was already discussed in here, but I couldn't find it. How may I put the language bar in winstep? I remember that sometime ago, when I installed it, this language bar was automatically attached to the taskbar.
Cheers and thanks in advance.
 Post subject: Re: How to add the windows language bar to the taskbar
PostPosted: Thu Sep 30, 2021 4:08 am
Do you mean how to add the language bar to the quick launch area of the NextStart taskbar?
If so then open NextStart preferences (right click the Start icon) and add a hotspot.
https://ibb.co/48WtJx4
Apply this and the Language bar icon should appear in the Quickstart area.
[Moderator's note: Added image directly using
Code:
[img]https://i.ibb.co/k4KBMFq/image.png[/img]
-DD_Ric]
PostPosted: Fri Oct 01, 2021 7:37 am
That`s exactly what I needed. Thanks a lot!
Users browsing this forum: Amazon [Bot], Google [Bot] and 167 guests
