Board index : Winstep Forums : General Discussion  [ 36 posts ] Go to page 1, 2, 3  Next
 Post subject: Weather incorrect
PostPosted: Fri Nov 12, 2021 10:09 pm
The current weather on the icon hasn't been right since yesterday. It says 56 degrees but it's currently 89 degrees. If I mouseover the icon to see the 5 day forecast, which actually only shows today/tomorrow, then it shows the correct temperature.
How do I fix this?
 Post subject: Re: Weather incorrect
PostPosted: Sun Nov 14, 2021 5:14 am
Something could be wrong with the weather server you're using. What happens if you right-click on the weather module then left-click on 'Check Weather'?
Have you checked your settings? Right-click on the weather module then left-click on Weather Module Settings.
Under the list of cities, it will have the city that you chose. Under that, there's a pulldown. Make sure it isn't set to 'Never'. Mine is set to 'On the Hour'.
PostPosted: Sun Nov 14, 2021 5:55 am
Nothing changes when I click Check Weather. It has never done anything when I click that. I made a post in the past asking why that option never seems to do anything.
Yes my settings are correct. I haven't changed anything. My update time was set to Quarter Past.
It seems to be showing the right temperature at the moment but it's nighttime so it might be a coincidence. I did change cities just now to test it and it looks right. But it didn't show the right temps during the daytime. It was always in the 50s when it's supposed to be in the 80s. I'll check again tomorrow during the day to see if it fixed itself.
PostPosted: Sun Nov 14, 2021 7:09 am
If I remember correctly, I think there's some sort of delay issue with the moon module on the older version I'm using, but I don't remember if the weather module has the same problem.
PostPosted: Sun Nov 14, 2021 11:47 pm
Has there been a Nexus update recently?
Yea there's a problem with the weather module. It's 81 degrees right now and it shows 58. When I change to a different city in a different state and compare it with a weather website's temp it looks correct. But everything in my area seems to be all wrong.
When the weather icon shows the moon does that mean it's nighttime? Because it's always showing the moon.
If there was a new update or beta for Nexus I could try installing that?
PostPosted: Mon Nov 15, 2021 2:11 pm
Yep, there's a problem with the temps. My module is also showing incorrectly.
I deleted all of the entries in the Weather Module Settings under 'Advanced' and left them blank to see what it would do. Nothing changed. I even added a site, but that didn't work either. Obviously, the site I tried isn't designed to work with the module. To put all of the links back, just click on Default.
I don't have the latest version of Xtreme, so I don't know if that will correct the problem.
I'm waiting for Jorge's return, and I assume a new update.
In the meantime, if you want an accurate reading, right-click on the weather module, left-click on Detailed Weather Conditions.
PostPosted: Mon Nov 15, 2021 10:04 pm
Thx for confirming that. The 5 day forecast when you mouseover the icon stopped working also.
From what I've read this Jorge has been MIA for awhile?
PostPosted: Sat Dec 04, 2021 4:17 pm
Yes, but I am back now.
Weather is working correctly here. Perhaps it's a problem with your particular location?
Anyway, if you are still having this issue, right click on the weather icon and select "Weather Monitor Settings". With the Weather Monitor Settings dialog open, click on the 'Get Weather' button - this will create a raw log of the information received from the weather servers.
Navigate to C:\Users\Public\Documents\WinStep\, look for a file named 'Weather.log', open it in Notepad and post the contents here.
PostPosted: Sun Dec 05, 2021 8:18 am
Jorge, please provide how to post the log file here. I tried, but I got an error message that reads: The extension log is not allowed.
I didn't bother trying to use a third-party site because I'm not sure if there's something in there that needs to be redacted for privacy reasons why this site won't accept it since the file is so tiny, or there's some other reason why it won't accept it.
PostPosted: Sun Dec 05, 2021 2:01 pm
Just rename the .log file extension to .txt and open the file in Notepad, then copy paste the contents here.
PostPosted: Thu Dec 23, 2021 7:46 pm
Weather not showing 5 day forecast.
Only showing present temperature.
Weather.txt
/data/observations/metar/stations/CYOW.TXT
tgftp.nws.noaa.gov
HTTP/1.1 200 OK
Date: Thu, 23 Dec 2021 19:39:52 GMT
Server: Apache
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Last-Modified: Thu, 23 Dec 2021 19:07:35 GMT
ETag: "488be64-71-5d3d4f384af17"
Accept-Ranges: bytes
Content-Length: 113
Vary: Accept-Encoding
Connection: close
Content-Type: text/plain; charset=UTF-8
Strict-Transport-Security: max-age=31536000; includeSubdomains; preload
2021/12/23 19:00
CYOW 231900Z 20004KT 160V250 15SM FEW100 FEW120 BKN250 M11/M17 A3018 RMK AC4AC1CI4 AC TR SLP230
Got METAR Data!
/wxdata/weather/local/CAXX0343?cc&dayf=5&link=xoap&prod=xoap&unit=m&par=1023928134&key=712ce1c26b0de059
wxdata.weather.com
HTTP/1.0 200 OK
Content-Type: text/html
Content-Length: 43
Date: Thu, 23 Dec 2021 19:39:53 GMT
Connection: close
/data.aspx?src=vista&weadegreetype=c&culture=en-US&wealocations=wc:CAXX0343
weather.service.msn.com
HTTP/1.0 200 OK
Server: Microsoft-IIS/10.0
X-ActivityId: c2b1d5d8-e5e2-40e1-ab52-cf9a94b0e5bb
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Cache-Control: public, max-age=600
Content-Length: 1455
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:CAXX0343" weatherlocationname="Ottawa, Canada" url="http://a.msn.com/54/en-US/ct45.426,-75.701?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="C" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="45.426" long="-75.701" timezone="-4" alert="" entityid="24773" encodedlocationname="Ottawa"><current temperature="3" skycode="26" skytext="Cloudy" date="2021-12-17" observationtime="08:45:00" observationpoint="Ottawa" feelslike="0" humidity="74" winddisplay="17 km/h West" day="Friday" shortday="Fri" windspeed="17 km/h" /><forecast low="0" high="14" skycodeday="27" skytextday="Mostly Cloudy" date="2021-12-16" day="Thursday" shortday="Thu" precip="" /><forecast low="-6" high="7" skycodeday="26" skytextday="Cloudy" date="2021-12-17" day="Friday" shortday="Fri" precip="20" /><forecast low="-7" high="-2" skycodeday="16" skytextday="Snow" date="2021-12-18" day="Saturday" shortday="Sat" precip="100" /><forecast low="-11" high="-4" skycodeday="32" skytextday="Sunny" date="2021-12-19" day="Sunday" shortday="Sun" precip="100" /><forecast low="-6" high="1" skycodeday="26" skytextday="Cloudy" date="2021-12-20" day="Monday" shortday="Mon" precip="50" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Got MSN Data!
PostPosted: Fri Dec 24, 2021 5:12 pm
According to that log there is no reason not to show the 4 day MSN weather forecast.
PostPosted: Fri Dec 24, 2021 5:31 pm
That's what I am getting.
Also it doesn't matter which city or country I chose.
https://photos.google.com/photo/AF1QipP ... XFC6Czs_sP
It was working fine previously. This is something recent.
PostPosted: Sun Dec 26, 2021 2:13 am
Your post's link requires people to log in to a Google account - who has time for that nonsense!?
PostPosted: Sun Dec 26, 2021 3:05 am
I don't appreciate your comment suggesting pointing out information on an issue with the operation of a Winstep module as "nonsense".
If that's how you reply to someone letting the programmer know of an issue I would suggest you get off your high horse and grow up.
Merry Christmas
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 36 posts ] Go to page 1, 2, 3  Next
Users browsing this forum: Amazon [Bot], Google [Bot], IvarR and 165 guests
