 Post subject: How do you get a jpg file imported to themes?
PostPosted: Fri Nov 19, 2021 11:17 pm
How do you get a jpg file imported to themes? Thanks.
 Post subject: Re: How do you get a jpg file imported to themes?
PostPosted: Sat Nov 20, 2021 12:48 am
The only bitmap in modern Winstep themes that still tend to use the JPEG format are those for the wallpaper (and even there I would favour PNG - much less lossy with compression).
If this is what you want to do, insert a wallpaper into an existing theme, simply rename the JPEG 'Wallpaper', rename the theme's original wallpaper by adding a '.bak' extension, then copy the new wallpaper into the theme and Bob's your uncle.
Bear in mind that a JPEG - and almost any other image format - is just a single image, not a complete theme.
PostPosted: Sat Nov 20, 2021 12:05 pm
Thank you very much for that information. I will try that.
Users browsing this forum: Amazon [Bot], Google [Bot] and 170 guests
