 Post subject: [SOLVED] Nexus causing flickering in many programs
PostPosted: Thu Dec 02, 2021 5:10 am
Hello, Ive been dealing with flickering for about a year that only happens with nexus ultimate running. I switched browsers and still no luck. Sometimes its just the top bar, other times its my whole screen. Its getting very intolerable lately and happens a few times per minute. Ive added a video to show the issue, this is the nicer more modest version of the flicker I get. Im running two docks, one for desktop shortcuts the other with pop out drawers for my programs.
Nexus Ultimate version 20.10
Latest Display Drivers
Programs affected:
Microsoft Edge
Google Chrome
Spotify Desktop
Davinci Resolve
 Post subject: Re: Nexus causing flickering in many programs
PostPosted: Thu Dec 02, 2021 3:03 pm
Programs affected:
Microsoft Edge
Google Chrome
Spotify Desktop
Davinci Resolve
https://youtu.be/X2BmgGFKcKA
This could be a problem between your display drivers (which ones?) and the affected programs, or possibly a problem between Nexus and the display drivers, though the latter seems unlikely. This issue most likely will have to be addressed by the coder/owner of Winstep himself when he returns, I'm afraid.
PostPosted: Fri Dec 03, 2021 8:12 pm
What version of Windows are you running? Are you running a window skinning application like WindowBlinds, for instance?
Anyway, if you pause the video just before it flickers and then advance/rewind it frame by frame by pressing the "," and '.' keys, you can see that the flicker is the actual "basic" titlebar being painted for a moment where the normal titlebar would be.
I think you will be able to solve this by going to Preferences -> Tasks tab -> Advanced button -> and disabling "Show icons of running applications as window thumbnails"
This will, of course, also prevent Nexus Ultimate from displaying window thumbnails instead of icons in the running applications section of the dock(s).
PostPosted: Sat Dec 04, 2021 2:48 am
Amazing, this solved it for me!
(Windows 10 enterprise 10.0.19004 build 1904)
Truly appreciate your work and support.
Have a great holiday and thank you!
PostPosted: Sat Dec 04, 2021 2:55 am
I thought so too only its happened for so long with multiple driver versions and reinstalling as well.
Thanks for your time, his steps solved it for me!
PostPosted: Sat Dec 04, 2021 3:39 am
My pleasure. Happy it got sorted for you. :) And thanks for marking the thread 'SOLVED' - it really is so useful, especially for people who might be doing a search and then can see at a glance that their similar/same problem has been solved.
PostPosted: Sat Dec 04, 2021 8:25 am
Thanks, you too! :)
I know what was causing it, I just don't know WHY it's happening on your system. Personally I've never seen that happening on any of the Windows versions I ever ran.
Users browsing this forum: Google [Bot] and 195 guests
