 Post subject: Tiles?
PostPosted: Wed Jan 05, 2022 7:33 am
I know I'm acting like a noob here. I guess my aging brain is telling on me.
I can't seem to find a way to use any tiles as dock backgrounds. You know, like those discs that lean to one side? I see them on the products page in screenshots, can't make it happen. Help?
Jim Dillard
 Profile YIM
 Post subject: Re: Tiles?
PostPosted: Wed Jan 05, 2022 12:18 pm
You mean make a dock theme that uses tiles OR use a dock theme based on tiles?
If the latter, you will have to use the Themes tab specific for each dock: open the Dock Properties dialog (right click or double click the Nexus control icon), navigate to the Themes tab, and change the combo box at the top left from "Themes" to "Tiles".
PostPosted: Wed Jan 05, 2022 4:03 pm
Ok, that worked, only, there are no tiles other than the classic tiles. Squares, no discs or anything else.
Jim Dillard
 Profile YIM
PostPosted: Wed Jan 05, 2022 4:46 pm
AARRRGGGHHHH!!!
LOL, ok, the classic tiles worked. Then I downloaded a bunch of Object Dock tiles and now none work. Not even the classic tiles that come with Winstep. I am on Windows 11.
Jim Dillard
 Profile YIM
PostPosted: Wed Jan 05, 2022 4:56 pm
Ok, apparently I can create a new dock and use tiles, but I can't seem to change a zoomer to tiles. And I can't seem to change the tile background on a dock that is already tiles.
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 4:12 am
Got it sorted.
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 4:34 am
Good, was getting a bit confused reading what was happening lol
What exactly was the problem?
PostPosted: Thu Jan 06, 2022 2:49 pm
Probably Windows 11, I'm not sure. Now I have another issue. One person who downloaded my new skin, Dark Rogue, is having an issue with the calendar coming up blanks. He is just using Nexus Ult.
I have no idea. But I think he has both Nexus Ult. and Winstep Xtreme installed. He had double workshelves too, at startup. I think he has both running at the same time.
Not sure what is up with the calendar.
He is using older versions of both.
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 3:42 pm
He just updated to 20.10 Nexus and still any skinned calendar is blank. Unskinned is fine. Help?
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 4:34 pm
Can you ask him for more details? It might be an issue with the skin itself. There are other themes where the calendar module is also skinned, ask him to try those to see if the same thing happens. Also, a screenshot of the issue would be nice.
PostPosted: Thu Jan 06, 2022 5:00 pm
He has tried that. All skinned calendars come up blank. Has the module background, but just no numbers, etc. Themes with calendars unskinned (default) work correctly.
He has uninstalled Winstep Xtreme, was outdated anyway. He uses Nexus Ultimate. 20.10
I think he's on windows 10.
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 5:02 pm
The skin itself works fine on multiple PCs of mine, and other downloaders have no issues so far. Would you like a copy of the skin?
https://www.wincustomize.com/explore/winstep/942/
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 5:06 pm
Jim Dillard
 Profile YIM
PostPosted: Thu Jan 06, 2022 7:20 pm
Well, must be something specific to HIS system or configuration. But what?
These cases are very difficult to diagnose, as they cannot usually be reproduced elsewhere. The user himself must play with the settings to try and figure out what might be causing it.
He should perhaps create an account here and get directly involved in this discussion, to start with. :D
PostPosted: Thu Jan 06, 2022 7:53 pm
Well it seems he fixed it by upgrading Winstep Xtreme to the latest version. Thanks, Jorge! He will purchase a renewal probably soon. His has expired. He is the one my latest Winstep was requested by.
Jim Dillard
 Profile YIM
Users browsing this forum: Google [Bot] and 176 guests
