 Post subject: Assistance setup - Fixed.
PostPosted: Wed Apr 20, 2022 7:56 pm
Hey, so.
I have recently downloaded Nexus from //www.winstep.net/nexus.asp and the setup download was perfectly fine, however (Check attachment)
If there is a fix to this, please reply as I will be checking 20.04.2022 - 23.04.2022
[In-case Image doesn't work];
Setup was unable to create the directory
"C:\Users\Public\Documents\Winstep".
Error 2: The system cannot find the file specified
Please note that: I have tried to change folder name, location and even tried USB. I'm out of ideas. (After is says setup failed)
File comment: Backup for image.
Last edited by BigUncleRoadHog on Wed Apr 20, 2022 8:48 pm, edited 1 time in total.
 Post subject: Re: Assistance setup
PostPosted: Wed Apr 20, 2022 8:01 pm
Did you move the Windows Documents folder to another drive?
Either that or your security software is being overzealous (or just plain stupid, more to the point) in its anti-ransomware attempts and is not letting the setup application store data in the Documents folder (which is pretty stupid since that is what the Documents folder is for).
 Post subject: Fixed.
PostPosted: Wed Apr 20, 2022 8:44 pm
Hey! Thanks for the reply
I use the basic windows security, and my documents file is still in my C drive. (Main)
As I said in my message beforehand, I have tried to setup in different folders, drives and even USB's to no prevail. If you have any more tips I could try then please contact me again, however -
I fixed it, I was checking on my ransomware protection and it seems that "Controlled Folder Access" was in-fact blocking the installation, this has been disabled.
Thank you for your help.
 Post subject: Re: Fixed.
PostPosted: Wed Apr 20, 2022 9:09 pm
See? This is why I call those type of anti-ransomware "features" stupid, much like using a sledgehammer to drive a nail. They should WARN and ASK the user about what is happening and which action to take (much like a UAC prompt) not just blindly and silently block a legit operation on a legit folder.
As it is, most of the time the user will have no idea what is happening, why it's happening, and how to fix it.
Users browsing this forum: Amazon [Bot], Google [Bot] and 204 guests
