 Post subject: System Tray Setting
PostPosted: Mon May 16, 2022 11:42 pm
The system tray settings appears below the screen/dock whenever i click the system tray. I placed the dock at the bottom screen edge and I would like to see the options for connectivity above the dock. I had to place the dock to the top screen edge to see the entire options for connectivity. THis also applies for CLOCK Module that shows the calendar. Its not showing up if the dock is at the bottom screen edge.
File comment: screenshot of error
 Post subject: Re: System Tray Setting
PostPosted: Tue May 17, 2022 12:02 am
Download the v22.4 beta as described HERE, it should fix the problem, but please let me know if that is indeed the case.
EDIT: that beta is only available for Nexus Ultimate and Winstep Xtreme, not the free version of Nexus. If you are running the latter, sorry but you will have to wait just a little bit longer for the official release.
PostPosted: Tue May 17, 2022 12:07 am
The first photo is the dock at the bottom of the screen. (Shows incomplete options)
The 2nd photo is the dock placed at the top of the screen. (Shows entire and complete options)
Nothing shows when I click on the clock module which i configured to show pop-up calendar. I had to place the dock at the top of the screen for me to see it.
I want my dock at the bottom.
PostPosted: Tue May 17, 2022 12:21 am
Read the reply by Jorge Coelho *properly*, it has the perfect answer to your problem. And another thing, "You can't always get what you want...." ;)
Users browsing this forum: Amazon [Bot], Google [Bot] and 179 guests
