 Post subject: Startbar tasks buttons do nothing
PostPosted: Thu Oct 04, 2007 1:30 am
Nextstart was freezing with cpu maxed out, so I removed a weather program from the systray and that took care of that. My present problem is that the task buttons on the startbar don't maximize a program when clicked. Anyone else experience this problem? I've never had this issue in the past. My OS is Windows XP Pro.
PostPosted: Thu Oct 04, 2007 11:01 am
Do you really mean 'maximize' or do you mean 'restore'?
Anyway, mouse click actions on the taskbar are user definable. You can define these actions by opening NextSTART Preferences, navigating to the Global Preferences tab and clicking on the Mouse Settings button.
Hope this helps
PostPosted: Thu Oct 04, 2007 9:12 pm
Da, yah, that did the trick. Just color me stupid!
PostPosted: Fri Oct 05, 2007 3:47 pm
/me picks a paint brush and... :wink:
Those options are a bit buried in Preferences, it definitely isn't your fault. :D
Users browsing this forum: Amazon [Bot], Google [Bot], IvarR and 168 guests
