Board index : Winstep Forums : General Discussion  [ 44 posts ] Go to page Previous  1, 2, 3
 Post subject: Re: Backup crash
PostPosted: Fri Jun 03, 2022 11:52 pm
Ther IS a chance my existing RAM is faulty and causing this. Replaced it with new modules, backed everything up that was on c: and now wait and see
so far its been couple of hours without BSOD or rez flickering
i haven't tested workshelf or nextart backups yet (nexststart didnt cause any problems before, but its a very light config), but since i clean reinstalled my graphics drivers updated both gom and klite, if it works we wont know what was it
PostPosted: Sat Jun 04, 2022 5:45 am
Sometimes figuring out a cause is not as important as actually fixing the problem eheh
Example, the instability I told you about on the new Windows 11 PC. Would I like to know what was actually causing it? Of course. But do I REALLY care? Nah, it was a random thing, so all that matters is that it stopped :D
In your case memory would be a very likely culprit given the way WritePrivateProfileString works (there's a reason it's slow) and the size of the backup.
PostPosted: Sat Jun 04, 2022 7:12 am
well, if its faulty ram, it should still be under warranty so i can get it replaced.
if its something else in my system it'll come back and bite me in the ass sooner or later :)
if it was gom/codecs thing that were causing the crash, chance of someone else stumbling into the same issues are minor
PostPosted: Sat Jun 04, 2022 3:43 pm
hmm, interesting, updated gom and codecs, new ram, and still got an error
any ideas?
edit: 2 times in a row with GOM open but paused, then no crash after i closed GOM, then after that not even restart helped, only when i killed some of the apps running did it succed
PostPosted: Sat Jun 04, 2022 3:52 pm
Doh.
Long shot, but do you have more than one drive?
If so, let's try backing up to another drive. First make a manual backup specifying the new destination folder in the other drive - after this manual backups AND automatic backups should remember the new folder location.
Let's see if you still get an error when backing up into a different drive.
PostPosted: Sat Jun 04, 2022 3:59 pm
And if that doesn't work we will have to wait until after the official release of v22.5 for me to be able to mess with the backup code. That's not the kind of thing you want to accidentally scr*w up. :D
PostPosted: Sat Jun 04, 2022 4:43 pm
Doh.
good catch, ssd+hdd, and to make it more complicated i used symbolic link to put backup folder which is on hdd in winsteps folder on ssd
gonna test now
edit: Both tests to SSD (C:) and HDD (D:) crashed
PostPosted: Sat Jun 04, 2022 4:52 pm
Ah well... :roll:
PostPosted: Sat Jun 04, 2022 4:58 pm
Out of curiosity, how long does it usually take there for a backup to finish?
PostPosted: Sat Jun 04, 2022 5:02 pm
its long, but i couldnt tell you if its about a minute or a couple of minutes. dont think its more than 2 or 3 tho
nextstart is fast, but that isnt supprising its only 64 kb, vs 261 for the workshelf, as i only have few things set up in nextstart
PostPosted: Sun Jun 05, 2022 2:44 pm
Strange. Backup of WorkShelf here takes less than 15 seconds, and the backup file has a size of 219KB, so not too far off from your 260KB backup.
Maybe the problem is in how long it takes for the backup to finish in your system?
PostPosted: Sun Jun 05, 2022 5:45 pm
now i had several successful backups in a row, and i guess my mind was playing tricks on me, bc using stopwatch they last about 30 secs. will update when i manage to trigger a crash
PostPosted: Wed Jun 22, 2022 3:43 pm
So no more crashes, I guess?
PostPosted: Wed Jun 29, 2022 10:35 pm
they are still happening, but i had some other, offline issues to deal with
they dont seem to be memory related bc i have new ram installed and i stabilised my system. could be something in the registry maybe? i should do a windows reinstall but so not feeling up to it
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 44 posts ] Go to page Previous  1, 2, 3
Users browsing this forum: Amazon [Bot], Google [Bot] and 171 guests
