 Post subject: Dock set to autohide sometimes not popping back out - SOLVED
PostPosted: Sun Jun 19, 2022 9:36 am
Often when I bring my cursor up to the top of the screen where the dock is hidden the dock doesn't pop out, if I pull the cursor back and do it a second time then it pops out.
Nexus Dock Free 20.10.1174
Windows 10, 64 bit
3 monitor setup, dock is in the top middle of the middle monitor.
 Post subject: Re: Dock set to autohide sometimes not popping back out
PostPosted: Sun Jun 19, 2022 3:50 pm
There are a ton of settings to fine-tune screen edge bumps in Preferences -> Behavior tab -> Activation Settings -> Edge Bump Settings.
Have you already tried playing with those?
 Post subject: Re: Dock set to autohide sometimes not popping back out - SO
PostPosted: Mon Jun 20, 2022 5:15 am
Ah, sorry, forgot about those.
Increasing "Distance from screen edge that still triggers an edge bump" from 0 to 1 pixel seems to have done the trick.
Users browsing this forum: Amazon [Bot] and 205 guests
