 Post subject: Open apps icons
PostPosted: Thu Jul 14, 2022 9:20 pm
Hi all, googled this and didn't find an answer, is there a way to have Nexus Ultimate only show the icon of an open app instead of a small icon on an image of the open app? It's kind of hard to explain, so I'm going to upload an image that shows an open app (OneNote) that only shows the OneNote icon and 3 other apps whose icons are so small, they are hard to see. Thanks in advance.
 Post subject: Re: Open apps icons
PostPosted: Fri Jul 15, 2022 8:16 am
Preferences -> Tasks tab -> Advanced button -> disable 'Show icons of running applications as window thumbnails'
PostPosted: Fri Jul 15, 2022 7:00 pm
'Googled'? Why not use the forum's own 'Search' utility - far more likely to give you the right result/s. And, although admittedly there isn't anything like a user manual at present, have you ever considered exploring all the different options in Preferences and Dock Properties? That's certainly the way I approach any app new to me. One soon learns what makes that thing tick, as it were. :)
PostPosted: Sat Jul 16, 2022 11:14 am
But he should do a Backup of his settings first (Preferences -> Advanced tab -> Backup button) just in case he ends up painting himself into a corner and not knowing what he did or how to recover from that. There's literally a TON of different settings to play with. :D
PostPosted: Sun Jul 17, 2022 2:51 am
A ton and a half, to be sure. :D But yes, backing up first is always a good plan.
PostPosted: Sat Jul 23, 2022 6:31 pm
And another 'anus horribilis' spammer trying to play clever - quoted the OP, turned a full stop there into the spam link, and added a sort of 'same problem here' comment! Well punk, you'll have to get up a hell of a lot earlier to catch us out here with such an old turkey. :P :twisted:
Users browsing this forum: Amazon [Bot], Google [Bot] and 186 guests
