 Post subject: Network Module
PostPosted: Fri Jul 15, 2022 7:50 pm
The only thing I am missing for this software is an icon for the network and internet. With the normal systray there is an icon to tell you when you are connected to a network and when you are connected to the internet. Is it possible to show that in the dock?
 Post subject: Re: Network Module
PostPosted: Fri Jul 15, 2022 7:53 pm
Just enable the 'Net' module.
PostPosted: Sat Jul 16, 2022 11:11 am
He's running Windows 11 and he means the system tray icon, Nexter.
TiaMaster, if you are running Winstep Xtreme or Nexus Ultimate: open Preferences, go to the Advanced tab, enable 'Notify me of beta (test) versions', click the Check for Updates button, let the Winstep Update Manager install the beta.
If you are running the free version of Nexus you will have to wait a bit for the official release.
Users browsing this forum: Amazon [Bot], Google [Bot] and 189 guests
