 Post subject: Different theme for each tab in shelf
PostPosted: Tue Sep 27, 2022 4:58 pm
Hi,
Is there a way to set each tab (and it's background) to a different theme in the shelf? It would be useful because a user could easily and quickly visually tell which tab is being worked on. Thanks.
 Post subject: Re: Different theme for each tab in shelf
PostPosted: Tue Sep 27, 2022 5:01 pm
No, there isn't.
The only way such a thing would work given how different each theme can be from the other, would be a shelf with simple solid colors or textured backgrounds.
PostPosted: Tue Sep 27, 2022 5:46 pm
ok thanks. So there is way to customize each tab background in a shelf, correct?
Can you please let me know how I can achieve that?
PostPosted: Tue Sep 27, 2022 5:57 pm
No, there isn't, sorry...
I was just reflecting on what something like that would entail.
PostPosted: Tue Sep 27, 2022 7:35 pm
Sounds nice in theory. But in practice it would be a bloody nightmare and throw up huge potential for all sorts of problems I can see. Would really need a separate exe I think, with just simple choices of colours and/or patterns, not themeable in the normal way I'd guess.
Users browsing this forum: Amazon [Bot], Google [Bot] and 141 guests
