 Post subject: Notification Center is Missing in the Nexus
PostPosted: Fri Nov 25, 2022 2:40 am
Nexus used to have both Action Center and Notification center by using an internal command, Action Center. The notification center was removed when i updated to Windows 11. How can i get the Notification Center back?
 Post subject: Re: Notification Center is Missing in the Nexus
PostPosted: Fri Nov 25, 2022 7:15 pm
What do you call 'Notification Center' and what do you call 'Action Center' (try using a screenshot to explain the difference)?
Also, what version of Nexus are you running (top right corner in the About tab of Nexus Preferences).
And what version of Windows 11 (type WIN+R then Winver + ENTER) ?
PostPosted: Fri Nov 25, 2022 7:43 pm
My Nexus is Version 18.12
Please see screenshot of both Action Center and Notification Center.
File comment: Action Center
File comment: Notification Center
File comment: Windows 11 Version
PostPosted: Fri Nov 25, 2022 7:55 pm
Thanks for the screenshots.
So, what you call Action Center is what you get when you click one of the *system* systray icons (volume, net, battery, etc). To access this you would need to display the system tray on the dock and click one of those icons.
This said, you need to update your version of Nexus to the latest release first (v22.7).
PostPosted: Fri Nov 25, 2022 8:56 pm
Yes I do have the action center. I inserted a new dock item -> Internal Command -> Misc -> Action Center.
What I am looking for is the notification center. How do I display it using Nexus?
PostPosted: Fri Nov 25, 2022 9:16 pm
Suggestion, if you could add another Internal Command for Notification Center, that would be great!
Windows+N is the shortcut for it.
Users browsing this forum: Google [Bot], winstep and 230 guests
